Mugabetown - Whoretownin' At It's Worst.
Morning Ants - Some people are retarded... I have the work Rottie asleep under my desk and someone just bought a little rat like a chihauhua into the office and went to put it down until the boss told them off, we have big signs everywhere saying no dogs allowed, guard dogs on premises etc...
lol pls tell me that Butch ate the rat
She made some noises and the guy bailed with his rat - After saying you should have warning signs and should have that dog tied up... We have signs, you just can't read and if you did what you were supposed to you wouldn't have noticed the dog was in the office, once I am here it's under my desk and refuses to get up for anything other than another dog!
whats the rotties name Mel?
I used to have 4 of them when I lived with my parents
They are gorgeous and probably the biggest sooks as well, but I loved them
Suffa and Pressure are the two Rotties (Boss likes Hilltop Hoods) haha and then there is a Beagle named Howard...
I had one growing up named Emma, then I also had a German Shepard named Ralph and a Boxer named Buster - I love big dogs!!! Surprisingly more than cats :)
lol Suffa and Pressure - awesome names
I prefer dogs as well rather than cats as well
But no more pets for us - it's just too much
I need all the pets!!!!!!!!!!!!!!!!!!!! Other than birds, I don't like birds...
I have two cats, they don't like many people other than Zane and I because they are super shy... It's quite a shock when they don't hide when someone comes round to our place let alone if they let the other people near them... They are sooooo cute tho!
nice. You will be a great mother someday ;)
AHAHAHAHAHAHAHA nope... Ask #@Smity42 or #@Sick_R31 they witnessed first hand that I do not deal with babies well at all, especially in confined spaces like an elevator...
OH MY GOD I WANT A GREAT DANE!!!
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
