Mugabetown - Whoretownin' At It's Worst.
I am in a happy mood for a Monday becuase my car goes to Chris this arvo... Then German Club Wednesday then Zac/Greg are working on removing HICAS on Saturday so hopefully that means it will be a pretty good week...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
