Mugabetown - Whoretownin' At It's Worst.
For larger turbos they make more difference than smaller IMO. I doubt you could even tell.
Just like anything, work out what you want from a particular setup, and then research.
And do it once, do it right. Much cheaper in the long run ;)
Well the highflow 34 turbo will do exactly what I want, the only difference is I have a place that will do it with ball bearings for $1350 or one from Hypergear with a thrust bearing for $860.
thrust bearing is poor in comparison to ball bearings you want to know why?????
not just because ball bearing actually spool faster than journal bearings................
but....................
because......................
it reduces the oil flow required for lubraction and it increases the longevity / durability of the turbo compared to journal bearings
Might as well have gone a gt2867 brand new if you pay that much + cost of 34 turbo
A good hi flow option from hypergear that will bolt to stock manifold and dump can make more power than a gt28
This is what I was thinking, I can get a 34 turbo and highflow it for about $1000.
+1 the small frame garrets are a pain in the ass to bolt up to an Rb and they probably have no more power potential. High flows are pretty under rated
Clint was running a ss1pu early model and made around 350hp from memory on pump98 fuel.. Hi flowed r34 turbo + e85 should see easy power with stock response. I'm my opinion it would make a perfect street daily.
remove and purchase -9 Pete or T51r or both lol
But effort.
Are they a direct fit to the stock manifold and dump Pete?
I thought so?
Again, i was comparing a hihg flowed ball baring turbo to it, not a hypergear journal bearing one.
More making a point at what you're paying for if you go for a brand new one.
But effort.
I thought so?
Our "Journal bearing one", is more responsive then your ball bearing one, and last 10x longer.
Yeah I agree Pete, I'm very much leaving towards the hypergear. I want to get an ecu and injectors capable of running e85 but running and running in pump 98 until I either get a second car or have e85 scalable locally.
nah man. Clint was actually making 400hp at the treads
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
