Mugabetown - Whoretownin' At It's Worst.
Lol, don't get why small traders always come in so aggressive,.. Particurally since I was pretty much saying go with them anyway.
I know of a near new mirage for sale mike if you want a cheap second car.
That map ain't accurate Pete.
There is at least another United not far from me (not Helensvale as that's literally down my street) in Southport
Does it have E85? This is just E85 servo's, accurate as of about a month ago. Maybe united didn't update their website with that one yet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
