Mugabetown - Whoretownin' At It's Worst.
I am quite excited, I need to get new tyres and an alignment between now and then tho... So hopefully I can find Adrenalins on sale otherwise I'll put whatever it is I have on the rears on the fronts also so they are the same all round... Alignment hopefully happening tomorrow just waiting on a call back, was meant to happen Saturday but shit went wrong and so Greg did one by eye for me.
Yokohama are currently have a tyre sale - buy three get the fourth one free!
AD08R's come at me!
Ha! Yes, its happy laps this weekend hooooray :banana: :banana: :banana:
Cars not ready. :(
Have got some half shaft bolts thanks to #@FineLine, heading to a brake and clutch store this arvo to see if they can make me custom brake lines
ADO08R's come at me!
I might have to have a look... Although my rears are only a month or so old lol
Cars not ready. :(
Gheyyy... But Yay glad someone could help with the length!
Cars not ready. :(
will have to be drag day then mate.
Also Ants - If you didn't see it on FB this is the drawing I am working on... Still a lot to go but it's a start... If the finished product looks ok I will be doing a series of them...
  • Like 2
you got some skills there Mel.
I consider it an improvement lol
Haha well to be honest I've only attempted anything like this twice once was when I fist got my car to decide what front bar and wheels I wanted and the other was instead of buying wrapping paper for a bday gift haha... But both of those were just very basic...
Not great no, but it wasn't exactly economy driving either. I imagine quite a bit of fuel would be flowing when its developing 400hp.
Should probably put O2 sensors in to help that. Presumably there's only 1...?
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
