Mugabetown - Whoretownin' At It's Worst.
Spent 2 days on the o2 sensors.
$100 on specialty tools and a few skinned knuckles later, I have 1 o2 out FML.
Avoided engine out tho :P
Not engine out??? But I don't understand... :blink::P
Not great no, but it wasn't exactly economy driving either. I imagine quite a bit of fuel would be flowing when its developing 400hp.
Should probably put O2 sensors in to help that. Presumably there's only 1...?
wut? usually there are two 02 sensors on RB26
Strangely enough I only have one now that I could spot under my car
Found the second one on the top of my dumps, can't figure out what is going on with the plugs though. Got a pair of 3 wire ones, one flat plug one square.
edit: images
Couldn't for the life of me find another 3 plug one like the top one. Dunno where i'd be supposed to plug the second sensor into then...
Nissan made it idiot proof, the plug on the front o2 is flat and the plug on the rear o2 sensor is square
Defeated my o2s finally. Another custom tool for the collection.
now im guna need a new 22mm spanner...
I live my life a 1/4 of a 1/4 of a turn at a time
Edited by MagicMikeZ32
  • Like 1
Turbo xxxx ECU, injectors, fuel pump, FMIC, Hi flow cat (perhaps)
R34 Turbo Brodi $200
Turbo Highflow, Hypergear, $860
Braided Turbo Oil Line, Hypergear, $88
High Preasure Actuator, Hypergear, $120
ECU, Haltech Platinum Pro Plugin, $1,975
Flex Fuel Sensor, Haltech, $250
Injectors, ID1000's, $720
Fuel Pump, Nismo Intank, $385
Fuel Pressure Regulator, Nismo, $132
Highflow Cat, Venom, $250
Tuning, ???, $1,000
Total $5,980
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
