Mugabetown - Whoretownin' At It's Worst.
Nismo fuel pumps are only 275lph or something silly. Sure they bolt in but thats about it. 450lph walbro pump will also cost ~150 bucks less IIRC. If the R33gtst fuel pump mount setup is similar to the R32gtst it's a peice of piss to modify it to fit, though getting to the tank may be harder due to 33's being less likely to combust in a rear end accident.
You could probably easily go smaller injectors (720cc?) and shave off a hundred bucks. Also make sure you buy side feed injectors to suite your fuel rail, with the right size holes etc.
Really need a FPR? Making 300kw's here without one, but maybe there's different stuff on the GTR fuel system?
I wouldn't double the tuning, maybe add only 50%, for flex. You're basically getting two tunes in there. That's assuming you have no issues however, which can quickly add up unfortunately. I mean, best case, just a 98 tune, 500 bucks maybe. Worst case, things to wrong, flex tune, 2000 bucks isn't out of the question, so be ware.
you're also just missing little stuff. Turbo gaskets, new studs, fittings for Ethanol sensor and the like can add up to a few hundred bucks
You'll need to figure out how you're going to get the car to the tuner aswell, Everything you need to do is easy enough to DIY at home (and... satisfying to do, i'd recommend it), but with bigger injectors the car will be undrivable unless you can get the tune adjusted for the injectors. Not sure how easy haltec is to modify
Not compatible? So Walbro over Bosch 040?
If you say so. You've done it recently.
yeah, the Walbro pump is E85 ready and as Pete said flows more than nismo pumps.
It can be fitted in tank too (just like mine)
Yeah, budget for at minimum 2k in tuning costs with eflex
R33 fuel tank is completely different to R32, just FYI.
Not sure how simple it is to mount a walbro/040 in tank in an R33
well as long is its not mounted to the tank floor it'd be easy enough :woot:
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
