Mugabetown - Whoretownin' At It's Worst.
Replacing some of toothless' fluids in preparation for laps of happy on Sunday. Keen!
Hopefully there's no rain, keen to see the line up between Toothless and The SS :devil:
why is it toothless? do you have a dragon or something??
I can't remember who exactly named it toothless first but when I bought it the headlights were very cloudy, oxidised and yellowly green. Like the eyes of the dragon toothless from "how to train your dragon"
...I'm still working on making it shoot purple flames...
Dislike today... Tried to do the right thing by coming in for half day to get stuff done and so manager could run errands, was meant to be gone at 12:30, still here because the manager isn't back. And it's f**king raining so have to walk my sick ass through the rain to pick up my car when I can actually go. Should have stayed in bed :-(
see if you worked me - I would of told you to stay at home
They told me to go home... I just had to wait till they were back... But yay home finally and didn't have to pay for my wheel alignment and my number plates arrived...
pink plates aiiight?
Not talking about custom plates nate, just slimline of my normal off the shelf plates. But I don't think "they wont fit the car all of a sudden after 4 years" will be enough reason for qld transport to give me a replacement slimline front plate
oh really? my front slimline plate has the edge broken (been like that for at least 4 years) can I request for it to be replaced at no cost?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
