Mugabetown - Whoretownin' At It's Worst.
no. Just like everyone else you need to earn it.......unless I win 5M dorras then I help you if you are a good boy
I do earn it, I just have other things I need to pay for first :(
Dam brakes. To many options, can't figure out what i want to get.
R33 brakes bolt straight on.
Bigger ones are probably only a bit more expensive if i just get fronts.
But i might want to get even bigger ones later, in that case the 33 brakes would be easier to move on.
Or i could go straight to even bigger ones but i'd need to get 18's...
In which case do i get TE37s again or something else.
Argh decisions.
Argh decisions.
Easy decision: buy the Leopard :P
  • Like 2
Argh decisions.
what are you on about Pete?
Your 17in TE37's will have more than enough room for a big brake kit
Also new big brake kits cost a lot more than R33 GTR Brembos Pete
40 minute sessions at wakefield, and my GTR Brembos never smoked... Just sayin! They have become fairly underrated over the last few years. Though I have never paid 1800 bucks for them. My first set of fronts cost 800 with dba 5000 rotors and my full set cost 1300 with dba 5000 front rotors.
Some between 4 and now Mel :(
Now I'm going to get up and drive to Beacmere to meet a client I know and help them put all their work on a cloud
I'm actually really looking forward to this :)
  • Like 1
Have you moved completely to xero in house?
Front D2 kit is about ~2K,
R33 all round is 1800 bucks by the time you get them rebuilt etc
Get real brakes. D2 are rubbish.
Do it once, do it right. Cheaper in the long run Pete.
If R33 Brembos bolt straight on, that means all Z32 kits will bolt straight on.
Check out here:
http://www.conceptzperformance.com/Cart/items.php?Car_Type=300&car_cat=Brakes&CA=24&UID=20140720194920203.9.185.243
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
