Mugabetown - Whoretownin' At It's Worst.
then don't go for cheap shit Pete.
Get a big brake kit like Brembo F50 with 380mm rotors or Alcon or Endless or Project Mu
Oh I also forgot AP and Willwood
and make it worth it
its a r32 weekender, not a r35 track car ants...
380 is probably to big.
those akebono kits seem reasonable, mike did you say r33 (and hence 32) and z32 stuff is interchangeable?
It sure is. I ran z32 brakes on my car for a few days while waiting for new rotors to arrive.
Correct, R33 brembos bolt straight on to Z32 (front and rear), so if R33 brembos bolt straight on to yours, all Z32 kits will fit.
Beetroot is awesome :). Not on a chicken burger though... :/
I like beetroot but my Schnitzel burger with bacon, cheese and gravy does not need beetroot :angry: They jipped me on the gravy side of things too!
And before Greg says anything, f**k the 12 week challenge today!
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
