Mugabetown - Whoretownin' At It's Worst.
Woo Canada!
I have been reading things here and there about smsfs and how they can be leveraged for debt to buy investment properties... Scary stuff considering some of the dodgy advisors that moonlight as real estate agents and the such.
Woo Canada!
what does Canada have to do with that ^ Pete?
Well that will all have to take a back seat as my wife had a car accident tonight and the Suzuki swift has literally been sandwiched between two other cars and is no more
No I'm in Springwood Maccas with her
Poor ol girl was well shaken up but no injuries
What implications are there for SMSF investment in whisky?
From memory there are strict provisions regarding such investments were they cannot be consumed and must be strictly maintained for any impairment loss
Holy shit! Good to hear that she doesn't have any injuries. Have you got someone looking after the kids?
yeah. I took em to my parents place.
I'm back on the GC now
Thanks for the concerns
Shit Ants! Hope everything is OK
aside from the Suzuki and Jannica having some major whiplash (effects kickin in now) everything should be ok
Looks like we will be going new car shopping!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
