Mugabetown - Whoretownin' At It's Worst.
http://www.imperialauto.com.au/index.php/online-showroom/nissan-cube-cubic-ex-detail
I'm taking this for a test drive this morning. Thinking about buying one for my wife.
or...
She might be even more terrified of potential accidents, but the price is right... especially if there's room for some forced induction! :P
https://www.facebook.com/ElioMotors
Or...
If she wants something that going to withstand a bus attack, I'm considering selling my SC300. ;)
yeah, suggested the Nissan cube but too small
We certainly want a bigger car after what recently happened
A friend in Canberra has a Dualis, she is happy with it as a run around for her and the kids.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
