Mugabetown - Whoretownin' At It's Worst.
Heading up to Howells Knob Lookout tomorrow for a picnic with the family. You get some pretty good photos out there on top of the hill with ranges all around.
Another spot I've been keeping an eye on at sunset is Bullocky Rest. If you can drive out to the tip and take shots from Forgan Road over the water you'll get some awesome shots.
sounds very nice
May head out there at dusk but I believe I would lack the lens to take nice shots from forgan road :(
Hey Ants. If you are after 4 cyl and a bit raised check out a subaru xv. I test drove one recently, good to drive, uses bugger all fuel and has a 5 star Ancap rating! Oh and Hi all, tiring day was tiring!
Edited by Bunta
thanks mate
Will check it out
If you can afford to get yourself out there around 5:30 on a weeknight I can bring 2 photographers from work. We work just around the corner. I'm sure they'd be more than happy to go on a little photoshoot adventure!
I may be able to get out after work some time.
Nice shots.
Here's the route I'm taking tomorrow for a picnic. Anyone got any feedback on the route? I've checked the roads on Street View, but the quality of the images doesn't tell me much about how sealed it is in some parts. Want to avoid any loose stuff.
https://mapsengine.google.com/map/edit?mid=zI1PayDARcBQ.kjTgc9FmU-r0
Edited by Simink
    • Infiniti US are teasing a manual Q50 as a way to refresh a (very old) model. https://torquecafe.com/manual-performance-sedans-arent-dead-yet/ Can't be too technically difficult given the Z has the same motor with a manual gearbox......here's hoping there is a JDM version we can import here, that would save me a world of headaches
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
