Mugabetown - Whoretownin' At It's Worst.
Yup.
I don't like domestic flights let alone the thought of international, the thought of flying overseas makes me nauseous then a few unfortunate events relating to flying overseas just add to that, needless to say, could not fly Malaysian Airlines even if it is just unlucky at what has happened... But I am sure you will have an awesome trip...
We are contemplating USA end of next year, early 2016... Even then I am tempted to stop in Hawaii for a day or two so that it makes the flight a little bit shorter...
Also... Who can suggest some places I can get a custom colour rattle can made up so I can paint some shiz?
Yeah It pretty much cant be bad, no work for 4 months, hard to go wrong really.
Thats probably better, I wouldnt mind doing shorter trips to different places, but Anna is doing courses while we are over there so it sort of has to go that long. I would like to do like 6 weeks there, 6 weeks in europe, 6weeks in South Africa, ect ect. but yeah at the end of the day I have 6 months of leave built up and I can afford to take it half pay so there is plenty of scope for those other things down the track!
Sounds like a plan! I want to do Europe but doing to start with USA/Canada and then another time go and do Europe (mainly Finland and Germany because relatives over there). I want to go to Japan but not sure about anywhere else in Asia or africa etc.
Autobarn
That's what Bodo said, I have no idea if they will be able to get it close to my Metallic pink/purple pearl since it's two colours on my car to make it what it is but if they can get it even remotely close I will be happy...
Martin let me know of a place in Geebung that may be able to do it and I've heard there is somewhere in Strathpine but not sure where. Gives me a few options at least, hopefully one can get close...
Paint matching in a can will never be 100%
Doesn't need to be, just needs to be close so I can cover the white and grey primer until I am ready for a full spray :)
main thing is they need to be able to scan a sample. not just find a paint code
Yeah, I can take my fuel cap off for them to scan otherwise I have a tin at home which is a fairly close match and was used previously on a door handle when my car was broken into.
Japan aw yiiiisssss!!!
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
