Mugabetown - Whoretownin' At It's Worst.
Well its still something one needs to pay when buying brake kits from overseas.
Also, Akebono's don't fit. Dam.
Now i'm really intrigued about those Autech brakes. AP racing 6 piston kit with the same size rotor fits under my car, the rotor on the Akebono's is just too chunky. So its possible that these Autechs would fit. What isn't possible is finding the dam specs of them though
only for items costing $1,000 (inc. postage) unless tobacco or alchohol
and its customs duty then 10% GST on any imported good declared at >$1,000
Autechs are huge - and I bet they wont fit your 17inch te37's
have you seen Fatz brake sale thread?
http://www.skylinesaustralia.com/forums/topic/434418-fatz-big-brake-sale-grex-ap-racing-brembo-stoptech/
Well, good luck finding a brake kit for under $1000!
And for customs duty, what's involved there? never dealt with large overseas purchases before.
Just checked, can fit Alcon 365mm 6 piston kits. TE37's are awesome.
Why don't the Akebonos fit?
The caliper is to tall, the total diameter including caliper is greater than the internal void on the wheels.
Which surprises me, as as mentioned above i can fit 365mm kits and not the 355mm akebonos.
I see. I see
Buy the fronts in this thread ;)
http://www.aus300zx.com/forum/showthread.php?t=329553
Rears are cheap minus rotors/pads
Edited by MagicMikeZ32
Would require dumping 4K on new wheels first...
Heck I cold just buy another skyline or 2 instead of trying to get those brakes to fit!
Edit: picture of 3 different brakes.
As you can see the Akebono's (red) stick out about 10mm more per side than the AP's (black) with the same size rotors. The 365mm Alcons (blue) are in the middle but have a better profile which seems to match the TE37's slightly better (they also curve in towards the front). I'd have to take it off again to check but from memory it's actually the tip of the middle hump that clashes with the Akebonos, not the top hump.
^^^ spot the engineer
:P
I thought he just liked drawing pictures :P
I would have looked and gone ehh doesn't fit, new wheels needed... :D
The Akebonos are chunky as fuark calipers. If you actually see them, they're larger than life. Much like my... any way.
With puchasing from o/s. You pay the cost of the goods + shipping to supplier ($x). Pay 2.5% import duty (1.0025.$x = $y) then you pay GST on that sum so 1.1x$y
Ants would probably need to correct me on import duty value.
Just checking in all, I'm
Not actually dead haha
Still under the thumb?
http://www.skylinesaustralia.com/forums/topic/439623-brake-clearance-thread/ 375mm rotor, alcon 6 pot caliper behind a 17" TE37
What would one say if they were looking for a 33 gtst and it was for sale for 3700 with fmic hks blow off, no rego or Rwc
Is hks bov plumb back or atmo? If atmo that is one of the reasons there is no rwc. Also many holes were cut to fit the fmic and was the reo cut as well?
Cricket bat... Your cricket bat is rather large...
  • Like 1
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
