Mugabetown - Whoretownin' At It's Worst.
Well its still something one needs to pay when buying brake kits from overseas.
Also, Akebono's don't fit. Dam.
Now i'm really intrigued about those Autech brakes. AP racing 6 piston kit with the same size rotor fits under my car, the rotor on the Akebono's is just too chunky. So its possible that these Autechs would fit. What isn't possible is finding the dam specs of them though
only for items costing $1,000 (inc. postage) unless tobacco or alchohol
and its customs duty then 10% GST on any imported good declared at >$1,000
Autechs are huge - and I bet they wont fit your 17inch te37's
have you seen Fatz brake sale thread?
http://www.skylinesaustralia.com/forums/topic/434418-fatz-big-brake-sale-grex-ap-racing-brembo-stoptech/
Well, good luck finding a brake kit for under $1000!
And for customs duty, what's involved there? never dealt with large overseas purchases before.
Just checked, can fit Alcon 365mm 6 piston kits. TE37's are awesome.
Why don't the Akebonos fit?
The caliper is to tall, the total diameter including caliper is greater than the internal void on the wheels.
Which surprises me, as as mentioned above i can fit 365mm kits and not the 355mm akebonos.
I see. I see
Buy the fronts in this thread ;)
http://www.aus300zx.com/forum/showthread.php?t=329553
Rears are cheap minus rotors/pads
Edited by MagicMikeZ32
Would require dumping 4K on new wheels first...
Heck I cold just buy another skyline or 2 instead of trying to get those brakes to fit!
Edit: picture of 3 different brakes.
As you can see the Akebono's (red) stick out about 10mm more per side than the AP's (black) with the same size rotors. The 365mm Alcons (blue) are in the middle but have a better profile which seems to match the TE37's slightly better (they also curve in towards the front). I'd have to take it off again to check but from memory it's actually the tip of the middle hump that clashes with the Akebonos, not the top hump.
^^^ spot the engineer
:P
I thought he just liked drawing pictures :P
I would have looked and gone ehh doesn't fit, new wheels needed... :D
The Akebonos are chunky as fuark calipers. If you actually see them, they're larger than life. Much like my... any way.
With puchasing from o/s. You pay the cost of the goods + shipping to supplier ($x). Pay 2.5% import duty (1.0025.$x = $y) then you pay GST on that sum so 1.1x$y
Ants would probably need to correct me on import duty value.
Just checking in all, I'm
Not actually dead haha
Still under the thumb?
http://www.skylinesaustralia.com/forums/topic/439623-brake-clearance-thread/ 375mm rotor, alcon 6 pot caliper behind a 17" TE37
What would one say if they were looking for a 33 gtst and it was for sale for 3700 with fmic hks blow off, no rego or Rwc
Is hks bov plumb back or atmo? If atmo that is one of the reasons there is no rwc. Also many holes were cut to fit the fmic and was the reo cut as well?
Cricket bat... Your cricket bat is rather large...
  • Like 1
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
