Mugabetown - Whoretownin' At It's Worst.
Hmm, someone selling a set of 33 brembos for $1800 bucks. Seems a bit steep...
Pete - get on it
http://www.ebay.com.au/itm/R33-GTR-Front-Brembo-Brakes-JDM-Nissan-Skyline-Drift-Silvia-/321333757526?_trksid=p2054897.l4275
you could also pick it up since your in Brisvegas
What's involved in fitting 34 items to 32?
you either have to put inserts in the caliper to take the bolt size down to 12 mm and use the r32 bolts or drill the hub out to 14 mm and use the r34 bolts to mount the caliper
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
    • Isn't there a PAR engineering gearset that has closer to stock ratios? And they claim they'll do whatever ratios you want.
