Mugabetown - Whoretownin' At It's Worst.
I want led highbeams already. But they don't make any to fit r32s (yet) supposedly.
also I need to wire it up so my hid low beams stay on when high means are activated.
Led or hid? Led would be too dim
Yeah intercooler is huge. Bar has been hacked up to make it fit. Interesting on the led department ... only car I have seen to run led headlights was the holden effjay concept thing and it had a monstrous cooling system behind a 20ish watt single led
Here is another potato quality picture that shows how bright it really is, very spotlight-like beam, which combined with the HID lens lights I already have gives a very full spread. Even if I've only fitted one side so far.
Looks ok. Might have to find myself a second set of 33 headlights if they work out.
Longevity will be the deciding factor, these are cheap ones from eBay. Also, all led headlights like them use a tiny fan on the rear to cool the aluminium heat sink, I have run them for 5 mins in a go with no significant heating, but if the fan goes or lets moisture in they will probably die... Will keep you posted
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
