Mugabetown - Whoretownin' At It's Worst.
Survey says 535.9rwhp at 21ish psi. Tried more boost but had spark issues. Chucked in a new set of coppers and it got worse and that was the end of tuning. Didnt even get to start bringing timing back in.
Goes hard tho. 2nd gear no longer very useful
that's great numbers Mike
In fact that's 400rwrk
What fuel did you use?
I'm hearing good things about twin GTX2863's in the -5 housings. upper 400kw's at all 4's, full boost earlier than normal -5's.
Wonder what other companies have cooked up though, all I really hear about is BW and Precision, but they both only really make bigger turbos
yup!
I think that my next build / upgrade will incorporate them
Hmm, a little under 400km's from Toowoomba United to Kawana to home. To Jerry can or not to Jerry can. I guess there is the united in Bald hills if i get desperate on the trip home.
Pete there is also one is Caboolture mate just up past the train station
Id jerry can it. That way you have peace of mind
The store in Caboolture is 400km's from my house to leyburn to it. However there's a store in the 'switch now which is a perfect midpoint, so i'll be right. Bring on the weekend!
I was meaning more of a pit stop on your way up to Kawana for a top up
    • I'm not a big fan of the Cometic gaskets either, as above the head and deck need to be like a mirror (can't remember the RA) so Kamieri sounds like a good idea.  FWIW a mate of mine hordes old motor stuff and has some blank unground Nizmo cams for one of these in his supply if random shit if you're interested.
    • This is aem disk setting in aem tuner and still 180 dgree off or ignition on exhaust cycle is it from cas it self as cas seems wouldn’t fit in cam shaft if wrong position and wiring been verified any ideas
    • Oh yeah that would work excellent. Should be the same diff housing & everything. Shoot me a text or call me 260-750-2246 -Cody
    • Oh right, I didn't realise it was your car. Please do! Makes me feel better about mine. I also have a big scrape on the front left bumper where someone presumably used the wall to guide the car into a parking spot  But somehow all the funds go towards mechanical things and the cosmetics stay forever unfinished... Interesting, I don't think I have seen it before. But after seeing @PranK's rusty roofline on the BMW I'd probably leave it alone. Wouldn't want water to get in there.
    • Thanks mate, thought you might know the answer.
