Mugabetown - Whoretownin' At It's Worst.
Survey says 535.9rwhp at 21ish psi. Tried more boost but had spark issues. Chucked in a new set of coppers and it got worse and that was the end of tuning. Didnt even get to start bringing timing back in.
Goes hard tho. 2nd gear no longer very useful
that's great numbers Mike
In fact that's 400rwrk
What fuel did you use?
I'm hearing good things about twin GTX2863's in the -5 housings. upper 400kw's at all 4's, full boost earlier than normal -5's.
Wonder what other companies have cooked up though, all I really hear about is BW and Precision, but they both only really make bigger turbos
yup!
I think that my next build / upgrade will incorporate them
Hmm, a little under 400km's from Toowoomba United to Kawana to home. To Jerry can or not to Jerry can. I guess there is the united in Bald hills if i get desperate on the trip home.
Pete there is also one is Caboolture mate just up past the train station
Id jerry can it. That way you have peace of mind
The store in Caboolture is 400km's from my house to leyburn to it. However there's a store in the 'switch now which is a perfect midpoint, so i'll be right. Bring on the weekend!
I was meaning more of a pit stop on your way up to Kawana for a top up
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
