Mugabetown - Whoretownin' At It's Worst.
You know why they call it off roading......once you do it, your car is off the road (especially if you own a hilux, they love having naps on their side)
2.5 hours mo fo's!!! stupid rain.........
That's because a lot of dumb asses go looking for trouble. In 11 years of driving off road for work I have never had an issue, even in hiluxes! Edited by Bunta
How are we all
Mike I had some of this last nite
Was epically disappointed
I'm hoping it was due to either my cold not allowing my taste buds to fully work or it's a dud
Just the standard 15yo? Not had that variety before.
yes. Standard 15yo but it's the solera reserve which has had some really good reviews and awards
It's 14yo brother is sooooo much better
It was all watered down
I'm thinking it was a bad batch
Should just open the Snow Phoenix to make up for it ;)
I did, going for a nice price now. But I'm still glad I had the opportunity to drink some.
just can't justify the price - if it were $200 bucks less I would have snapped it already
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
