Mugabetown - Whoretownin' At It's Worst.
We've been over this before....
ECU isn't compatible. Plenty of servos around. Why bother.
orly?
The reason I ask is because of this
Dalby Ethanol Bio-Refinery under threat of closure. - See more at: http://www.unitedpetroleum.com.au/united/news/news-item/news/2014/02/17/dalby-ethanol-bio-refinery-under-threat-of-closure-#sthash.i1z8FdYx.dpuf
Almost didn't stay up for the race last night. Glad I did :), but boy am I going to pay for it today. Struggle street... :S
Pretty sure I will be going home this arvo to watch it online... I like 4 or the top 5 so I will like the race at least :P
Yeah. And by carrying jerry can problem solved. In fact I can fit 2 of the 20L ones in easily. It was really more of a question of do i stop at every servo along the way or do I take the Jerry can so I can stop less to save time, As I was trying to cram Leyburn and Kawana into one day. My range is limited however, yes, but honestly I don't think that i'll need to go further than a bit of planning will allow at any point in the future.
Part of it is also that i'm still trying to get a handle on the economy of the new Fuel. I was getting 17-18L/100km on the first few tanks but these were city and spirited driving, so max 400km from a tank. From T'bar>Leyburn>home>Logan servo on Saturday I averaged 14.7L/100km which is much better, almost 500km/tank range there.
Once I get the O2 sensors in hopefully it'll be even better again!
I travelled to and from bribie island though so there was some km's involved. I left my house with a full tent got to the BBQ point with half tank, threw in my 20L then drove home and once I got there I had half a tank again. A lot better than I expected really
Guess it's less painful paying $1.25 p/litre
  • Like 1
Mitsubishi ASX is a POS but fuel efficient... Just don't try to overtake, or corner at a normal speed on a slightly rough road... Needless to say it was over 10hrs in a boring car on the weekend...
What ecu are you using Pete? Nistune?
How will narrowband O2's help with e85?
Better off removing closed loop IMO and tuning for a targetted afr at cruise ;)
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
