Mugabetown - Whoretownin' At It's Worst.
We've been over this before....
ECU isn't compatible. Plenty of servos around. Why bother.
orly?
The reason I ask is because of this
Dalby Ethanol Bio-Refinery under threat of closure. - See more at: http://www.unitedpetroleum.com.au/united/news/news-item/news/2014/02/17/dalby-ethanol-bio-refinery-under-threat-of-closure-#sthash.i1z8FdYx.dpuf
Almost didn't stay up for the race last night. Glad I did :), but boy am I going to pay for it today. Struggle street... :S
Pretty sure I will be going home this arvo to watch it online... I like 4 or the top 5 so I will like the race at least :P
Yeah. And by carrying jerry can problem solved. In fact I can fit 2 of the 20L ones in easily. It was really more of a question of do i stop at every servo along the way or do I take the Jerry can so I can stop less to save time, As I was trying to cram Leyburn and Kawana into one day. My range is limited however, yes, but honestly I don't think that i'll need to go further than a bit of planning will allow at any point in the future.
Part of it is also that i'm still trying to get a handle on the economy of the new Fuel. I was getting 17-18L/100km on the first few tanks but these were city and spirited driving, so max 400km from a tank. From T'bar>Leyburn>home>Logan servo on Saturday I averaged 14.7L/100km which is much better, almost 500km/tank range there.
Once I get the O2 sensors in hopefully it'll be even better again!
I travelled to and from bribie island though so there was some km's involved. I left my house with a full tent got to the BBQ point with half tank, threw in my 20L then drove home and once I got there I had half a tank again. A lot better than I expected really
Guess it's less painful paying $1.25 p/litre
  • Like 1
Mitsubishi ASX is a POS but fuel efficient... Just don't try to overtake, or corner at a normal speed on a slightly rough road... Needless to say it was over 10hrs in a boring car on the weekend...
What ecu are you using Pete? Nistune?
How will narrowband O2's help with e85?
Better off removing closed loop IMO and tuning for a targetted afr at cruise ;)
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
