Mugabetown - Whoretownin' At It's Worst.
early morning work shift. Gotta do stocktake this afternoon too which I'm definitely not looking forward to. Missed Jambo yesterday which I'm not happy about.
Looks like some really good numbers were run. Nitto II being the stand out RB Skyline, one run into the 7's and another at 180mph
Morning all
Yes, Scottie you should have come along I was there, finally got to meet Noel, saw my old boss (Damien Mckern), Nitto II was nutz, had a great day despite being crook
Adams R34 GTR Monster
Nitto II - running a big ass Precision Turbo 7.second GTR
post-5053-14094357218343_thumb.jpgNoel's beauty
Damien's 20B RX3 aka grump2
Was an awesome day out
Great photos Ants. Definitely wish i was there. Yeah Nitto II runs the Promod88 Precision, is the same engine & running gear out of NITTO [R34], then they changed out the 88 sequential box for a powerglide
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
