Mugabetown - Whoretownin' At It's Worst.
Pete, if you're serious about investing, take a look at the reports that have just been released and see what some experts opinions are. Personally, I think that commsec give a fairly even report on what's what.
We won 2 awards at the Australian Institute of Project Management Awards late last week.
Construction/Engineering Project in Excess of $100,000,000
And
Project of the Year.
Will look good on the CV if nothing else :D
Yeah, doing some research on my week off, so thanks for the tip of what to be looking for.
Mangs, long time between posts...scarnon?
http://www.booktopia.com.au/the-intelligent-investor-benjamin-graham/prod9780060555665.html?source=pla&gclid=CN-Fy5vz1cACf*kJvAodLa0Aeg
Pete the above is a good a start as any in terms of investerment education. It is a very dry read but covers all the important stuff.
Would not recommend apartments Andy. Way too many being built at the moment for there to be any decent capital growth and rental yields you can do better buying blue chip shares.
Melbourne and Sydney are experiencing it already with rents dropping near the city as more apartments get built and landlords start competing for tenants.
Yeah, that's what's turned me off of investment properties.
Apartments are going to be oversupplied, houses have already grown so much they can't really grow too much more (bar local inconsistencies I suppose).
Sad afternoon today though, the Suzuki is gone. On the plus side it means more funds for my Dad to restore the Datsun.
With long term in mind and no mortgages to deal withI can't really lose. Borrowing the money would be a different story.
Just this year my shares lost something like 60,000. I was just lucky that at the last minute that was recouped by CBA
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
