Mugabetown - Whoretownin' At It's Worst.
Day 1 of our new structure at work, goodbye job satisfaction! *waves*
That bad huh?
My work restructures all the time, in other words everyone else decides to do less and I get even more :dry: And there are only 3 people in the office!!!
Yeah they split our functions into 2 teams. Assessment and compliance. We used to do both and it was good for our careers, have really well rounded skills. Now you are either glued to a desk or dealing with dumb complaints all the time.
so, you should now say that you 'specialize' in either Assessment / compliance Andy
That's a possibility I guess. Being overly specialised in my field isn't always a good thing though!
that is true.
However, you know that you can and have been working with both components up to now.
just don't forget that
Also spotted a white Stag with an R34 front end conversion, had a GTR badge on the grille but I didn't see if it was a GTR front end. Pulling onto Samford road on the range between Samford and Ferny Grove.
Why is everyone putting spotted posts in whoretown?
This offends me :P
I didn't rrealiseit was whoretown till you said that...I just saw Mike's post and assumed it was the spotted thread.
standard 34 front does not fit, needs the GT-R front to fit the wide track
seeing as this is now the spotted thread, saw PEte today heading gold coast bound on the M1 in the GT-R, gave him a toot as he drove past me doing 120 and didnt even get a response !
Slacker
Slacker
What a rude prick...
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
