Mugabetown - Whoretownin' At It's Worst.
Morning! Everyone ready for the drag day?
I'm excited! Car is mostly ready. Have new denso plugs and splitfire coilpacks to go in if I get motivated. Only other thing to do is to make sure the MT's are ready!
who gives a shit when you can say "I run 20 pound of boost" aint nobody gonna mess with you when they hear that ;)
I'll say 'I run infinity boostz!' that will get the bishes wet :yes:
  • Like 1
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
