Mugabetown - Whoretownin' At It's Worst.
So, if i go down to my local TMR office with my front plate and this form filled out with section 8 ticked "other" and write in something like "improved cooling", would i be able to get a slimline plate?
ask TMR
Anyone got any experience with OBD2 scanners? I am looking to get one, but not sure what works and what doesn't :(
Is yours actually OBD2? Thought that it might be too old? Can lend you mine if you like. As long as you have an android phone or tablet with bluetooth, it will do the job
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
