Mugabetown - Whoretownin' At It's Worst.
Not hiding, just left the page open while I do EOM data extraction/validation.
Been going flat out, headphones on, smashing everything out. Found something totally stupid among the 4300ish projects we manage and I accidentially said 'oh you f**king retard', out loud. Probably extra loud since headfones on. Everyone killed themselves laughing.
Edited by MagicMikeZ32
  • Like 1
lol Mike
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
