Mugabetown - Whoretownin' At It's Worst.
This sounds serious. Is this for the tissuebox?
Pete, if you're gonna rid yourself of that wing, I know someone who'll happily buy it from you, ME! ;) I figured you're not, but it was worth a shot.
Yeah nope, car needs it.
Would be interested to see what you do with it however...
put a big ass drag wing on it Pete.
I promise never to say anything about it being riced up.
but I doubt I could refrain from doing so
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
