Mugabetown - Whoretownin' At It's Worst.
Was a lot of fun, the SS is a pig to skid...the benefits of a car up for track. Also she has started running really lean under load, anyone have suggestions on a cause? I suspect the fuel pump but don't know how to test it.
test voltage of fuel pump
I would mate. But no spare cash FTM and that would mean burn more money for 50kw. Not chasing more power anymore but focus on handling, reliability and response
#NAPRECRB26
Those turbos will be more responsive than your existing ones supposedly. 50 (or more) extra kW is just a bonus.
But yeah, cash monies are the problem. Would be 2k out of pocket in the end.
My car started running really lean for 1 dyno run yesterday, the tuner 1st thought dodgy fuel pump till I told him I bought it off him less than a year ago lol.
Turned out that a tiny vac hose going to the fuel pressure regulator had come off under boost. Anything like that on these engines?
If nothing simple like that, fuel pump and filter are next to look at.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
