Mugabetown - Whoretownin' At It's Worst.
Don't do it Scott...
Only reason Id sell is to go better
whats going on? Or not going on??
Motor needs a few G pumped in to push it to where i wanna go. There also been a good motor come up at a good price that im finding hard to avoid
an already built motor is generally always cheaper than paying someone to build one from scratch for you
Just make sure that built motor has what you want
If you would like to know more send me a message. Dont want to make it public knowledge yet
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
