Mugabetown - Whoretownin' At It's Worst.
Yeah, it's like that... Zane agrees F**k that butttt Money! End of next year things should settle down a little :) Just so much going on over the last and next 12 months need all the money I can get lol
Well, changing plugs (from BCPR7ES to BCPR7ES... doh), fuel filter and oil and my missfire appears to have gone the one time I actually got on boost. Fingers crossed for the drags on Saturday
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
