Mugabetown - Whoretownin' At It's Worst.
I will also be heading down, provided I don't blow up my car. Otherwise I'll have to get in on this plan B...
If you blow your car up, plan B wouldn't appeal to you.
Is plan B go to Canadia?
Yes, yes it is. Since dates haven't been posted last week when they were supposed to i suggest booking flights right now :whoops:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
