Hey all,
Can anyone suggest a shop I can go to around Sydney to get a battery which will fit right in? Car isn't starting on some mornings and just now after a drive it didn't want to start. Turns over then clicks, low on juice. Voltage when running is about 14 - 14.2v which would indicate the alternator is fine.
Ive called a few shops they all either cant be stuffed or don't know. Someone suggested "any battery will fit". Can't see how since there is very limited room. If I go dry cell can the battery be mounted flat? There isn't very much room at the moment between the speaker and negative battery terminal and the battery in there is tiny. Its a century branded battery and its much smaller than the battery tray in the car.
Sum it up, new battery from where, how much and wet or dry?
https://www.sau.com.au/forums/topic/431334-drop-in-battery-for-r33/
Get the model code off the battery? 45Z or something I dont know, If its a century battery it will be on there.
Depending on what you want will depend on where you go
If you just want another centry, run of the mill battery, go to supercheap auto
I don't feel this battery is suitable. It is far too small and since Ive had the car its always been abit laggy on cold morning starts. Also have a sound system in there, not too big but again a battery that small will be pushing it. Thinking of getting an Optima battery but unsure if they will fit.
Slip down to the Optima guys & let them do the thinking for you man. Done deal.
Cheers GW
I've just replaced my battery. After doing the ring around I ended up at Super Charge at Blacktown who found me a battery that was the same size - with the pencil sized terminals - that fit perfectly in the standard tray. The battery was a MF40B20L and although RRP was around $130 they let me have it for $90 - bargain. It's a fully sealed, maintenance free battery so no loose vapours in the boot and is rated at 360CCA which also aligns with the standard specs.
If your running a few amplifiers and like leaving the stereo on without the engine running, or you have one of those alarms that just loves to slowly drain your battery over a few days, I would recommend replacing your battery terminals for some larger sizes. You would then be able to get a fractionally larger battery rated to around 450 - 500CCA and that would keep you cranking on the coldest of mornings.
Z
I'll give them a call and see what they suggest. Just went down to the local and the chap suggested the same battery I got in there, the 40vlsx or something or rather. I don't leave my stereo running when the car is off, but I do think my alarm is one of those drain your battery in two days type.
Zane can your sealed battery be fit in any position?
Just an update.
Called up a few places, ended up going with a SuperCharge MF75D23L. Was only $140 so not bad at all. Has twice the cranking power compared to my old battery, much larger, greater capacity and its sealed. It was a straight fit, old terminals were fine but I had to make a longer securing bracket on the top of the battery. 5 minute job.
If you're after a battery for your R33 and need something a little bigger, consider the MF75D23L. 3 years replacement warranty too.
Edited by SargeRX8
  • Alarm (pretty common, pulled a faulty one out of my mate's car not long ago)
Ghey window lift kits
ABS relay constantly on
Relay for ECU on, constant power to it
Faulty Amp, constantly staying on regardless of trigger wire
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
