Happy Laps - Queensland Raceway 27-10-13
  • Replies 288
She can drive a manual, it will just hurt her foot.
I shall try my best to convince her, but I give myself a 0.000000000001% chance of success...
I know she can manual and it hurts her foot...broom duct taped to the pedal and you can hand operate the clutch for her :yes:
If you thought passengers giving directions was bad...
I could make Connie actually drive the SS how she deserves instead of being looked after...
You going to have the Maxima out on the track?
There is a possibility. If I can get the wheel bearing in by then, then maybe.
That's not the issue. The problem lies in finding time!
heres an idea.........borrow Gregs Holden POS and you give the Mugabemobile to Greg (+ wheel bearing minus booster seat)..............problem solved
bet ya tims balls you dont have the Maximus track ready by next week.
Yeah. And it's all because I'm out there enjoying my merry life and not breaking my balls for the club and getting shit like this put together. :)
I'm sorry, but that was a f**king low blow.
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
