These are the 19" JDM VENERDI wheels that just came off my recent import. The finish is immaculate! they look like they were taken out of the plastic yesterday. No hint of rash. Marks in the picture are just from rain last night, these are real head-turners.
Standard Ford/Japanese fitment. 5x114.3,.... 19x8.5 (all 4) and approx +30 offset.
Comes with the pictured Michelin tyres that vary from 5-20% tread, probably not roadworthy at all, but they fit the size perfectly, 245/40/19.
Inspection and pickup from Hampton Park (at Scotty's place :)
started at $1200 but for SAU member I am open to best nearest offer.
Also on Gumtree so they may go, but holler if you're interested.
EDIT: in VIC, sorry.... should have been clear in the title.
Edited by Kazal
https://www.sau.com.au/forums/topic/431743-venerdi-jdm-19-wheels-shiny/
Alright, so it's early price-drop time. Seeing as the Gumtree ad is causing me to get Phishing fake PayPal emails... I will hope that SAU members are friendlier!
Down to $1000 the set!! Inspection welcome with notice (as long as Scotty says ok) Hampton Park, Melbourne.
Yep, that's fine. Inspections welcome.
That picture doesn't do them justice, I couldn't find one gutter rash or mark on the face. And great tyres would get you buy for a few months to save for new ones.
It's a shame to have to be doing this, but the wheels are now going for $650
Someone take them off my hands and help pay my insurance excess from theft attempt on my Stag please!!!
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
