I have standard twin GTR blow off valves 32 or 33, not sure but I think they are the same anyway, chasing an adaptor plate for one or both that I can have welded to the intercooler piping. I don't have the standard crossover pipe. Lots of aftermarket ones are to suit specific blow off valves like the greddy or turbosmart ones. I do also have the standard pipe that the twins bolt on to but hoping for something a little neater and compact.
Thanks
Liam
Edited by FordyR31
https://www.sau.com.au/forums/topic/431783-wtb-factory-gtr-bov-adaptor/
Thanks, it seems most adaptors are to use a different bov on the factory crossover pipe. I have wondered if you can reverse this and attatch the bov to the part that bolts to the crossover pipe and weld the the little tube intended for aftermarket bov to intercooler piping.
I have that part already, the bovs came attached to it but thanks. Looking for something much neater but it seems custom is the way to go.
This is what I have already.
Edited by FordyR31
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
