hi there did a retarded thing and hooked battery up wrong way fryed my ecu and turbo timer have replaced both of them and the fuses the car runs now but it has few problems.
have lost power to rev gauge headunit and windows
there is a round black relay that clicks every 10 seconds and the power drops fuel pumps quitens and dash lights dim
tryed replacing not 100% sure on 1 i put in but it clicks aswel
any 1 have any idea what would be wrong cheers
ok so i found a melted ground from where turbo timer was grounded have replaced that didnt solve anything,
video of running
have been told could be blown regulator in alternator cauing overcharge im going to test what the battery is putting out tonight
i just cant under stand how everything runs fine like temp gauge and heater indicators head lights etc but just windows and rev gauge wont work and the clicking relay and possibly headunit going to replace fuse in back of it and plug it back in.
hopfully try putting new alternator on aswel otherwise i think ill have to take to sparky
Edited by 25plusturbo
also i tested the battery and my results were 12.3 when 1st hooked up battery from my 07 hilux when relay clicks 11.9 , car runnin 14.3 clicks 13.9 after turned off 12.7 clicks to 12.3 havent tested from alternator but from what i seen from battery it isnt over charging, was just wierd that i couldnt jump start it i had to put battery from truck into laurel and started mint
will unplug it and see what happens on the ceffy
after u jump start it remove jumpers from hillux.if alt is working it should be at 13.+ volts 13.6/13.9 etc
using same battery that u put the wrong terminals on?
could have blown one of the cells inside, i have had a case where a bat was showing 12v+ and not starting only to find battery was gone, fixed with a new bat
if i unplug it it runs fine and doesnt click but something must be wrong with the rev gauge and windows must be a ground somewhere tripping it.
when i tryed jump starting i had batt in that got hooked up bakwards it had dash lights n everything but like died when i went to turn it over even when leads hooked up. i will try replace the alternator tonight just to see if it fixes anything
okay so i pulled apart the dash loom and followed the clicking relay wire and it went to the window amp in the passenger door must of fryed it aswell, unplugged it and clicking stopped, windows started working again except passenger havent been able to check rev gauge as manifolds off getting planed but im guessing it will be working
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
