Is this possible? Ive heard the RB20DET's arent know for their huge power outputs. If this is possible and someone has achieved it could you please let us know what setup you've used or if you know of a setup possible to get these sorta times. Would it be a better option to put in a RB25DET and go from there?
Cheers
Chris
https://www.sau.com.au/forums/topic/43186-rb20det-in-an-r32-running-low-11s/
... or if you know of a setup possible to get these sorta times. Would it be a better option to put in a RB25DET and go from there?
I dont think getting the power out of an RB20 in an R32 GTST to run an 11 is that difficult, i think its the car setup required to do it can get expensive.
A few ppl have commented my car should run an 11, some even say easy, but i doubt it will....not because of power, but the rest of my car wont allow me to run that time. (actually the driver may be a limiting factor as well :Oops: )
I have an RB20DET with Trust TD06-20G with 10cm housing, Trust exhaust manifold and Type R wastegate, GTR 444cc injectors, re-written Jap ECU, AVC-R, HKS Type S cooler, HKS air filter, R33 Series II AFM, 19 row oil cooler, HKS Hyper 3" exhaust with cat and both mufflers, Whiteline works susp package and UAS GTR 6-puck clutch and flywheel(sprung centre), and 225/45/17 D01J rear rubber. (with std open wheeling diff)
I have no idea about the power my car makes, about 2 weeks ago it was on a dyno and made 180rwkws at 0.65 bar (may have been 0.8 i cant remember) AFM was playing up so going Z32, and the mixtures were bad, so getting a re-tune next week after the engine gets some std GTR cams and adjustable cam gears this weekend.
Power, i dont know, this turbo has made 260rwkws on an RB25, i have seen an R32 GTST in NZ makign mid 240rwkws (without cams)...so hoping for at least 230rwkws, without having to wind too much boost into it.
So friends say 11, tuners says 11s (once the Maps are cleaned up), but the cars clutch cant be slipped off the line, so means getting off the line will be either dump and spin, low revs and bog, or ride and burn :rofl: . Also 225 rear tyres aint the best for traction, i can fit 245s on the rim and arches, but i couldnt afford 245s when i recently bought rubber.
Then i have an open wheeling diff, not good for traction off the line, and there is the suspension im using, (2rismo gives me heart as he ran an 11 with Whiteline susp) and along with the firmness of my shocks/springs, my alignment aint ideal for drags, its actually set up for sprint laps around circuits (though i never seem to drive at the track :Oops: )
Next Friday at Calder, ill give it a run and see what time i do, i expect between a 13.1 and a 12.7, as i have never drag raced my car before. I know of a few cars that made over 300rwkws just crack into the 11s with the right rubber and repeated attempts.
The quickest RB20DET powered R32 i know of is 12.7 (a time i will be stoked with)
Very difficult, but possible - I have watched an R32 GTSt w/ RB20DET run an 12.2 in NZ, but that was using NOS and slicks. Esp. if you want to do it with a road car/street tires, I'd guess an RB25 would make it heaps easier - just because of the response/turbo driving ability.
  • 4 months later...
whut abt that white one with Microtech in HPI, ran 11?
I think the one your are talking about is MattR's old car (forum member) It had a RB25 in it, I think it ran about 11.7 or 6 on slicks
The car was stolen and burnt not long after, so it went no faster
Clint32's R32 ran 12.8 on stock internals and injectors, very good time for stock motor
LOL...so 12.8s the benchmark then. Will have to see how i go this friday, i reckon im about a 20:1 of not even getting under 13.5:(
There is a R32 GTS-T RB20DET with Slicks and a Stock Bottom end running high 11's down here.
Just a cheap cam grind, Link Computer, T3/T4 turbo, Custom intake and exhaust manifolds.. it's not consistent but has done a couple of high 11's. Best of 11.8
I don't think it runs any Nos also.
Also on a stoc GTS-T box.. they don't last long.
I was suprised..
Yeah, Clints time is pretty stout for a RB20 I reckon. At the time it was making around 230/240rwkw I think, RB25 box and GTR mech. LSD
I have been to the drags once, and I sucked! At the time it was with my previous tune (ie no fuel and no timing in mid-range) and the best I could manage was a 14.0 at 104.9mph, my 60ft was 2.4ish. Axle tramp and diff where the main prob
My suspesion was also not well suited for drags, overall I thought my car would run mid 13's, but it wasn't to be
Do a few runs just driving of the line, and get a feel for what mph your car is capable of, you will need around 110mph to run a 12, maybe a bit more
Have a go mate, be kind to your gearbox too
My experience has been that the problem with the RB20 isn't max power, you can easily get enough to run 120 mph. But the power band gets so narrow that they get really hard to get off the line and that makes 11's a bit of an ask. As Roy posted, bog and die or wheelspin city.:P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
