Ok guys, just wanting some proper clarification, not what you "think" is true, or what your brothers mates cousin friend told you he heard once.
Is the 32 GTS4 box the same strength wise as the 32 GTR box?
I know they have different ratio's, but have read conflicting info regarding strength, some say weak, some say same internals as GTR box or 25det manual box.
I just want clarification before looking at one as a potential new car.
Cheers
Brett
FWIW, I have a R32 GTS4 running the RB25DET. It was initially tuned to 180kW at all 4 (factory is only around 115 @ all 4). It still runs the factory gearbox. The box is still fine, no synchro problems, no selection problems.
In my experience, Nissan gearboxes are TOUGH. Some people will tell you "I just broke my 4th box". I have to say they must really be mistreating the box. Treat the box right, ie no 7k-sidestep-the-clutch-launches, it will treat you right.
It is a KNOWN fact that the GTS4 gearbox is basically the same box as the GTR box.
The GTR box is basically the same internals as the other large frame Nissan gearboxes (RB25DET, VG30). It makes sense that they would go to the effort of developing the AWD box for the hi po car based on the existing strong gearbox. It makes absolutely no sense that they would then go and develop another AWD box based on the small frame gearbox (RB20DET) just to put it behind RB20s in GTS4s. Even though the little RB20 wouldn't need the strength, it would make the most sense for them just to bung the strong AWD box they already had behind it.
They are very similar. As a couple of examples, the mainshaft part number is the same between the GTS4 and GTR boxes, but different to the 2wd rb20 boxes. The bearings are the same between the GTR and GTS4 but different to the RB20. These are two indicators that they are of similar strength.
Cheers fella's, exactly what I wanted to hear, this has a 25 in it already and a few decent mods, has a rwd switch, so will be using that majority of the time if we get it.
Won't be abusing it, but if my mates can baby their GTR boxes with 500+hp and still have fun, then I'm sure I can manage with 400 :)
I'd say clutch selection is one of the most important factors in breaking gearboxes... steer clear solid centre clutches and mega clamp singles..
I did like the comment above from someone with all of 180kw that anyone who breaks one "must really be mistreating the box" ?
put decent power through them, with good grip and they're not indestructible.
That's not a fault of the gearbox. Its like blaming the kettle for blowing up after you took out the 10A circuit breaker and replaced it with a 6" nail.
My point about my "all of 180kW" shows that even with a 50% increase in power going through it, the box still works perfectly.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
