any idea why we are getting so many random spam posts, it seem to start with stupid reply posts now it seams %50 of the new topics and posts are spam bullshit.
im sure you are aware of it and its a pest problem so im not nagging but its getting worse at a rapid rate?
Edited by GH05T
https://www.sau.com.au/forums/topic/432490-massive-amount-of-random-spam/
It seems to have happened over the past couple of days Glyn when most regulars are not posting > but the spammers are.
On a PC or a tablet, the links they're using are of course easy to side-step; but on a mobile....gr-r-r
any idea why we are getting so many random spam posts, it seem to start with stupid reply posts now it seams P of the new topics and posts are spam bullshit.
I'm not sure of the source (maybe other admins are), but we are all busy cleaning them up. Looks like someone's already done the cleanup this morning.
It's basically like a war out there....the forums let us do certain things to block spammers, and the spammers keep finding ways to get around them. These days I guess they are doing the registrations manually because the registration controls are pretty good. There are further controls we can implement but they start to affect real users so there is a balance to be struck.
Please keep reporting when you see them so nothing gets missed.
Terry....school holidays!
where do they lead?
im not about to go clicking links but what are they pushing? just virus pages or pay by click adverts?
also thanks to the admin for keeping the floods of shit at bay.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
    • You can probably scrub the rust with a toothbrush or something. After you get the rust off flush well with water to neutralize and you will probably want to also use a fuel tank sealer to keep it from rusting again.
    • The sodium citrate solution is designed to buffer the citric acid to keep it from attacking metal quite so much, the guy that came up with that recipe did a ton of testing on how much metal loss occurs over time and it's nothing crazy unless you forget about it for months:
