Seems silly on the face of it. The whole point of camber is that when you apply significant cornering forces such that there is a force making the body roll out over the tyre, then the tyre wants to stand up. If the tyre initially has negative camber, then as it stands up it applies the tread face flat to the road, giving you the benefit of the full tread face generating grip (on the tyres on the outside.....the tyres on the inside of the car will of course have less contact patch, but they do a lot less of the work).
If the tyre has no neg camber, then as the car/suspension rolls, the tyre stands on its outside edge, giving you less contact patch on the heavily loaded outside tyres and you get reduced grip.
So, if the special camber tyre is built to be inclined inwards towards the top, yet still present a flat face on the road at static conditions, then there should be no difference between that case and the case where a normal tyre is set up with no camber at all. Load the special camber tyre up in a corner and it should stand up on its outside edge and offer reduced contact patch compared to a normal tyre that was installed at the same "camber" angle.
All the best trickery in this sort of context is in designing suspension systems that eliminate a such body roll as possible and therefore require less static camber, thus minimising the camber wear problem from driving a lot of camber in mostly straight lines. Add some caster into the mix and you have low static camber + enough dynamic camber to keep things working in corners.
This special camber tyre design seems to reek of being a solution to a problem that doesn't exist except in the lives of people who insist on running lots of camber because it looks cool.
I may have to back down from this position if serious evidence (not marketing material from the company) is available, but I wouldn't expect there to be heaps of that around.
https://www.sau.com.au/forums/topic/432550-camber-tyres/#findComment-7045016
+2 same here, looks like the tyres are designed for the stance crowd. Actually on the limit these look like they might be worse (contact patch reduces a lot quicker as the car is "tipping" onto the edge of the tyre). Plus different shorter inner diameter compared to outer, wouldn't that cause the inner to wear out quicker?
https://www.sau.com.au/forums/topic/432550-camber-tyres/#findComment-7045337
^So it has the same static footprint of a normal tyre, at a higher static camber angle...? This isn't going to change the effective footprint of the inner/outer tyres as the car goes through a corner, so what's the point? Wank?
Looking at it, the only way this could be marginally more effective would be if the car had no suspension at all, and thus these would offer a slightly wider track width while maintaining a full contact patch.
Edited by colourclassic
https://www.sau.com.au/forums/topic/432550-camber-tyres/#findComment-7045374
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
