Ooh bro no insurance, that wt made it even worse.
People have to start learning if you can't afford insurance for a skyline or havn't gotten around to organising insurance within a week of purchasing one don't get one, only makes the pain of theft worse.
  • Like 1
https://www.sau.com.au/forums/topic/432634-stolen-skyline/#findComment-7048567
To true.
https://www.sau.com.au/forums/topic/432634-stolen-skyline/#findComment-7049065
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
