https://www.facebook.com/groups/6216606658/permalink/10151802680211659/
A huge thank you to everyone! My thank you rant is on the FB page. :)
Cut and paste to here for those of us not on the Facebook page!
Tony Sivaa ▶ SAUQLD
1 hour ago near Chermside West
A big thank you to everyone who came to the charity cruise today. Awesome day was awesome sauce on an awesome burger!
Special thanks go to:
Martin Smith for judging best overall car
Anna Hahn and Andy for judging best engine bay
Stephen Elencevski for judging best exterior
Chris Rogers for judging best interior
The rest of the exec for making this happen, answering calls at obscure hours and for being so supportive. Andrew Osborne Chantalle Handley Zeke Farry Scott Bailey Michael Cadman Greg-O!
Daniel Smith for herding the BNR34 guys
The leaders of each group for getting everyone there in one peice.
mike James for herding the R35 guys.
Biggest thank you goes to Michael Cadman for organising the route and truly assisting in the organisation of this. Without him, this event would not have run anywhere near as smoothly.
At first count, it looks like we've raised about $2k for the Smith Family. We just need to recount and make sure that all is accurate.
Well done guys. An awesome day that wouldn't have been anywhere near as awesome without you! Ps, I can't tag any more people....
Thanks,
Tony
I will extend the thanks to all involved in making today happen!
Cheers guys!
glad to hear,was good to meet you,should keep in touch,us southsiders have got to stick together,catch yah next time.
IMG 20131208 100557
  • Like 1
Thanks man! Wouldn't let me copy pasta on phone. :(
Thank you so much for rallying up the south side boys.
Tony my wife got heaps of photos on the camera will post up as soon as I can .
Also thank you for a very organised meet thoroughly enjoyed this years cruise
  • Like 1
will be some good pics in there, she was quite snap happy. look forward to seeing them.
My Videos from the entry into lakeside will go up as soon as theyre uploaded
  • Like 1
Thats a great shot of Phil's car (R35)
and my bro's R32,
was great being the meat between that sandwich while cruising LoL
Phil leaving me behind and the R32 pushing me along.
Was great just being in attendance with alot of GREAT cars
  • Like 2
Yea man she has so many photos I was like wtf when I went through them ..lol
Entry vidZ yes please
  • Like 3
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
