Also this turbo is brand new all fittings an it a replacement for an 01 WRX apparently from what I could find??
TBO TD05 - HW
Does anyone know if it's any good an should I try swapping it for something to fit my cat??
Cheers
Daryl
I know folk put TD05's on Skylines. Check the forced induction thread.
Suppose it would depend on the rear housing, flange and inlet pipes on your 33.
Sorry cant help much....
What about the BOV would that somehow replace the stock one I'm using an is there any point, I can't see a brand NMR on it but it's in new condition.
Also could I canablize the turbo actuator for mine or best to just sell it to a WRX owner.
Daryl
There is No need for you to replace the stock BOV you already have.
Skylines use a Plumb back setup where the BOV releases the pressurized air back into the system via the BOV return pipe which lets the air return back into the intake pipe, between the Airflow Meter and the turbo where it will be used.
This air has been measured by the Airflow Meter which tells the ECU how much air and the ECU then allows a suitable amount of Fuel to go with it.
The BOV you ask about, is an Atmospheric BOV, meaning that it will release the Air outside of the Engine.
Doing this, the ECU will have allocated so much fuel to match the measured air, but that air will no longer be in the system so there will be too much fuel. This is notorious for causing the engine to stall in Gearchange and clutch in situations.
If you get an ECU that runs a Manifold Pressure Sensor instead of an Airflow Meter, it won't be a problem and you can use any old BOV you like.
Other downsides to an Atmo BOV is they draw unwanted attention from the Police as they create excessive noise and also the fact that oily vapours are being released into the air instead of being burnt off in the engine.
That and the Tosser/ Wank Factor.
Sell it and use the Funds for stuff you need. :yes:
Edit* it looks like an HKS SSQV BOV or a fake one.
Look Here ---->> http://www.dsmtuners.com/forums/bolt-tech/455246-how-spot-fake-hks-ssqv-bov.html
Those wide rims that come with the car aren't that bad the spokes are grey enamel an look ok with a bit of shine not to much rash, still have not idea how to clean under the car steering rack etc it's to low at the front to get up on ramps, anyone know a trick.
Some guy down the street have me a pair of BMW racing leather seats,
Well on BMW rails but easy to swap over , I think?post-120922-13821702582164_thumb.jpg
Right price anyway.
Cheers guys, hope you don't mind the running commentary ,
Just a quick stupid question as I'm still waiting on my workshop manual,
Changing sparkplugs , are they under the splitfire coils? also I brought a set of Bosch P38-6
FR 7KPP 33U+
Bosch
Platinum plus
Are these plug any good as there the best they had where I went.
Cheers
Daryl
Yes. Undo the loom plug going to a coil, unbolt the 2 little bolts (on diagonal corners) of the coil. Pull the coil out. Sparkplug is there.
Platinum is overpriced and unnecessary and can actually have a weaker spark than coppers...
$30 for six NGK BKR6EYA Coppers or BCPR6ES Coppers.
These should be pregapped to 0.8mm. If you get them with 11 at the end, they are pregapped to 1.1mm.
The smaller the gap, the less likely the boosted air will extinguish the spark.
Most if not all of the answers to your questions ie. sparkplugs, BOVs etc are available in the Forced Induction, Tutorials / DIY / FAQ and General Maintenance sections as all these things have been asked and covered many times over...
Not having a dig but the search bar works wonders with queries. I use it all the time. :thumbsup:
I got these plugs from supercheap I got a 2000$ gift card from insurance when the house got robbed so I get what ever I need from there that's why I got em, but if experience says don't use em, I'll put them away as spares.
I just found a shit load of Victorian paperwork in the glovebox I couldn't open it before because of the gauges .
There are 2 Dyno tune workshop receipt for a tune saying
1) dated June 2 2012
Before tune....
Torque 519 Nm Torque 382 LBS/FT
Power (KW) 156 Power (HP) 209
Speed 119kph
After tune
Torque 589 Nm Torque 434 LBS/FT
Power (KW) 219. Power (hp) 293
Speed 146kph
2) dated August 9 2012
Torque 598 Nm Torque 441 LBS/FT
Power 216KW Power 289 HP
Speed 142kmh
So I'm going to make some phone calls tomorrow an find out what's been done as when I brought it if this woman she didn't know anything much about it, she got it for money her ex owed her.
Now I know the ex's name an number an his tuners name an number.
Cheers Daryl
Like I said, Not having a go and I / we are always happy to help but yeah, most of this I know as a results of searching for the answers to my own queries.
Ok the skyline has been Dyno run at ultimate, is putting out 164.6RWKW@154KPH, 257N.m@148kph
9psi boost
Has bigger garrett hj300?? Turbo
And everything's already there to get min 230+RWKW with a aftermarket ecu an a safe tune.
So ill shut up now, I'm happy it's a solid engine all the aftermarket stuff is there down to a 3in exhaust system.
Thanks for your help guys.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
