I was told yesterday it was running really rich an can't change that till it's tuned but better than lean ?
But they were talking to a Nissan moron ,now I know how other people have felt when I'm going on at a mile a minute on other topics.
Larger turbo on stock ECU will run rich
To protect the engine.
No chance of getting 280kw with just a computer.
As zebra said, chances are that it's got stock injectors, fuel pump and AFM because its the stock computer.
So max with those parts and a tune is around 210-220 but with a larger turbo its going to be a laggy 210-220 I would guess.
So start planning what you want and we can help try come up with what you will need.
The mechanic I seen yesterday said he'd have it running 280kw in a week, but what we spoke about the haltech platinum piggyback I'd have a safe 220-230 but your right about injectors , regulator and pump.
Are I tank fuel pumps a hassle to install?
I'm about to run an injector cleaner through a full tank but still have to find out about the fuel system
Thx
Have a good look at you injectors and compare with photos on google images.
If your keen, take out the fuel pump and do the same.
If you spend a bit of time reading : http://www.skylinesaustralia.com/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/
You will see what is actually needed to make power, and what does nothing.
What i learned is if you have a bigger turbo and want more power, you need more fuel. The standard fuel system only has enough for a slightly bigger turbo, and small power gain.
And you need a computer to run it of course. A Nistune is suitable for anything thats not making heaps of power. ( for rb 25s i dont know exactly how much )
Almost anything else you do to the motor wont give more power, like wanky bov's etc. But things like an upgraded cooling system can keep it in good nik longer.
Dont forget the cheap effective things like exhaust and intake, though you may have most of that done already.
Personally id make it run nice with the turbo you have, and concentrate on handling.
Theres a lot of bits and pieces to make it handle good. It can eat up a lot of cash.
I couldnt use all my 180kw because my diff was stuffed, no point having power you cant use.
Ps: im jealous of your wastegate actuator, thats nice and simple, reliable and adjustable.
Edited by D.I.Y. Mik
fuel regulator usually isnt needed as upgraded injectors dont need more pressure.
unless your going for huge power
How can the mechanic say 280kw without knowing what its got.
Not being a flamin mongrel.
Trying to help.
Haltech piggyback is the most ridiculous thing ive heard.
This isn't 1999 anymore.
Nistune will do everything you need for half the price and as a bonus will actually work.
Car wouldn't run with bigger injectors.
If they are purple they are stock.
Ok.
So what you want is.
And this depends on budget too.
Nistune or a powerfc.
550cc or larger injectors.
Larger fuel pump. Walbro or something similar
Z32 MAF
Metal intake pipe
Then better than stock clutch (im partial to os giken)
Then tune by someone who knows what they are doing...once again my preference to take it to yavus at unigroup engineering in sydney (I wont ever take my car anywhere in canberra, but im a fussy prick) others are happy with a couple of the locals.
There arent many highflows that will do 280rwkws on 98 so expect 240-250 at the most.
Now you have a quick car that needs to stop and steer better. So factor in good suspension stuff. A good diff Centre and work on the brakes. New rotors and good pads are enough for most.
Ok.
Z32 MAF
Metal intake pipe
:yes: exactly
Just found out the guy I brought the skyline off in apr cashed in the rego 2 days after I did the revs check an I've got to re rego it , have to either replace the steering rack or stop the leak.
3 new tyres and kill 6Db, also raise the adjustable coil overs they do hight but can I do it or do I have to get pedders or such too, same principle as a motorbike shock I think but I want the adjustment to be exact.
Also thought about adjusting the boost with the adjustable rod but don't know what distance to boost it will make.
That's where I'm at.
Also looking for a maf befote tune.
Cheers
Oh also found out they wound back the tacho it's got about 300000 not 169000 as it read , is anyone honest anymore
But compression check an engine check is healthy so don't know what to think
I will never do biz in vic again. That's 3 times now I've been screwed down there .
Be careful not only in Vic but every other state. Normalllllly - SAU people are fair honest - as we are a little tight knit community. I purchased Rosie from vic (SAU seller) and it was quite a good deal. Nothing wrong with it and all in good nick - all I could ask for was a little less lazier seller :P
cheers
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
