Hey guys trying to put a microtech lt12s in my 33 4door. I've got a plug and play set up but the power circuit was f**ked. So we've found a new power for the Ecu and plugged it in.
The hand controller said everything was ok and we set the tps to 0 then tryed to start it.
The starter motor was turning it over then stopping suddenly and ticking like the battery was flat. So with the jump leads hooked up to my room mates car we tryed again and it did the same thing, Then it stoped and jus ticked.
So thinking we've done damage we've out the old chipped Ecu in and it's still doing the same thing.
I'm pretty sure I've done the starter motor but I don't understand how. I'm also keen to jus see this Ecu work but so far the plug and play has given nothing but trouble
Can anyone help out please
https://www.sau.com.au/forums/topic/432912-rb25det-wont-turn-over/
Kk now I've discovered I can turn the engine over by hand anti clock wise then when I go back the other way it gets to a point and stops like its locked up. But yet the car was running and driving this morning
Kk jus about to put the other starter motor in. But we jus discovered with the starter motor out I couldn't turn it clock wise either but I put a breaker bar on it and pushed hard as f**k then it turned over and seems fine now. Ill try another jump and another starter and fingers crossed it works
It gets hard to wind by hand because it has compression.
I told you in the first reply to check some voltages and this would have eliminated electrical fault with the start circuit. Hard to help people when they dont listen....
Mate compression isn't that tight. U can always turn it over by hand with effort. But when your pushing hard as f**k and it don't go that's worrying.
I was getting worried as my room mates n12 did the same thing jus before it blew the Ecu.
And was kinda hoping for some advice on microtech plug and play as well.
I was told it would jus go when it pluged in but now I've got no spark and my exhaust is loaded with fuel from tryin to crank it.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
