Well for something different I have been on a new anti depressant and various sups for a while now and just failed a work drug test fun fun
LOL from your prescribed medication and legal supps? Surely the failure of the test won't matter then right?
I don't touch the stuff. But getting stood down from work until retest kind of sucks. Had to give them a list of what sups and meds I take.
Balls. Surely when it's cleared up you'll still be paid for the period you were on stand-down?
Your Housemate Troy:-
If he starts things and goes off onto tangents, is bubbly but gets scatty or off with the fairies, always needs company, has loose bowel motions, complains and whinges > quite probably is bipolar.
If he's a loner, broods, interfering, manipulative, opinionated, feisty, defiant and stubborn > probably short on serotonin ie passive/aggressive
He loosely fits into parts of both those categories, lol. It's really hard to tell as he's been dealing with whatever it is for quite a few years, so he's actually really good at just dealing with it. You wouldn't know he had suspected bipolar at all unless someone told you :( But definitely fits more into the bipolar "symptoms" you listed there.
A bit of an update, the mrs grabbed some Swisse Mood pills for me.
Have been taking them for the last month along with some Fish Oil, Swisse Men's Multi, Immune booster and B12 pills.
Have also been gymcercising for the last fortnight and things seem to be getting a little better. Still got a short fuse from time to time but things are appearing to get better. When something big happens, that will be when I know more.
Shall see how this goes and keep you guys posted. Hate going to the GP so haven't ventured that path yet.
Thanks for all your advice.
  • Like 1
haha pretty bloody much hey! He and his partner's cat is actually f**king awesome, it's so close to a puppy it's not funny. Whenever his mood sinks into depression, Stitches (the cat) seems to be able to tell straight away and is immediately REALLY affectionate and loving towards him, which helps heaps. Best cat I've ever met, might as well be a dog lol...I mean it was practically raised like one :D
Fuark! That sucks mate!
Can you get a doctor's certificate to prove that you haven't been taking anything illicit? That may assist your cause and help you get back on sooner.
Yeah apparently. Just got called back in. Apparently I can drive normal vehicles but not trucks...... Can't do high risk activities even though my job consists of nothing but high risk activities playing with electricity
Only had to state meds afterwoulds and also spoke to the work doctor who said current meds and sups would not cause a non negative result. After woulds I than tried a in house test and it failed to read thc ( not failed not passed ) I than tied another one which passed. It's been a slow slow day
Edited by Kenna802
A workmate failed his because he ate a poppyseed muffin 2 days prior. If you can delcare, they let you stay at work provided it isn't illegal. He couldnt work it out until a doctor mentioned poppyseeds. He had a 5 day holiday.
The fun continues . Had to drive to Brisbane yesterday there and back , all up 6 hours travel in a work car. I would hate to think if there are people that fail the test that are smokers who they give the benefit of the doubt and make them do that.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
