  • Replies 64
Yeah id have to agree there, Im a big follower of the F1 and chances of those figures being exact is slim, not to mention they usually like to match engine power to certain circuits. Renault actually recently went through with a engine upgrade for this weekends canadian grand prix with a myriad of changes resulting in alleged increased power.
https://www.sau.com.au/forums/topic/43313-hp-of-f1-car/#findComment-884095
I think in F1 they spend more in one race than a leading V8 supercar spends in the whole year, does that explains it?
I remember somewhere that bridgestone quoted for every tyre that makes it to the track atleast 10 would have been used up in testing
https://www.sau.com.au/forums/topic/43313-hp-of-f1-car/#findComment-884186
Fomula 1 car's HP
  Teams             PS
1. BAR-Honda    925
2. Ferrari           915
3. BMW              905
4. Toyota           890
5. Renault         885
6. Sauber          880
7. Mercedes      875
8. Jaguar          870
9. Jordan-Ford  840
10. Minardi        830
no ownder Honda is so fast. The different between best and the worst is 95hp :)
yeah, but jaguar is known to have a fast car. as seen by webbers qualifying and practice capabilities.and theyre number 8. its just that it struggles to finish.
https://www.sau.com.au/forums/topic/43313-hp-of-f1-car/#findComment-884231
i think the problem with jag is cosworth......americans are useless pricks!
nevertheless Jag are in trouble next year with HSBC likely to back out so Webber better leave as soon as he can
https://www.sau.com.au/forums/topic/43313-hp-of-f1-car/#findComment-884470
Cosworth is British and their achievements in any form of racing can not be scoffed at.
They supply three F1 teams (Jordan, Minardi and Jaguar) with engines, albeit they are all different to each other.
Jaguar's engine is a brand new design and still under some sort of development. They only had 1 engine failure this season and it was electrical. Webber still managed to finish 13th in that race.
Michael Schumacher won his first championship driving a Cosworth powered Benetton in 1994.
Enough of Cosworth, where did those power figures originate from...? Do they have dyno graphs...? :bahaha:
https://www.sau.com.au/forums/topic/43313-hp-of-f1-car/#findComment-884516
Cosworth is without a doubt English!
I'm sure I remember M schumacher saying a while back that none of the cars are over 1000hp presently and it was unlikely they would break that barrier in the near future, which at least partially supports the list above. More gains were to be made from aerodynamics
https://www.sau.com.au/forums/topic/43313-hp-of-f1-car/#findComment-884540
Nissan would be mad doing f1, i remeber Toyota claim to be a dominate team by the third season, and where are they at the moment? after spending Well over $100 mill. euro last year. F1 is a case of having the techno resource pool to go looking for results, Something that money cannot solve overnight.
https://www.sau.com.au/forums/topic/43313-hp-of-f1-car/#findComment-885289
i thought the exact same until I heard james alan on the commentry saying that it was american based....Im sure that Jordan and Jag are using the new spec cosworth engine although I am deffinite that Minardi are using a lower spec but better in reliabilty, having said that their lap times are 2sec quicker than last years and are fairly close to Jordon this year.
i dont think horspower is as much of an issue as you guys are making it....its the whole package, especially aero, reliabilty, low centre of gravity and balance that makes a good racing car.... and everyone in the paddock knows who has the most hp as everyone knew last year that williams had the most (which was most noticeable on long straights) yet Ferrari still claimed the world and constructors championship!
https://www.sau.com.au/forums/topic/43313-hp-of-f1-car/#findComment-885403
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
